โJul-04-2017 05:41 PM
โJul-06-2017 10:43 AM
โJul-06-2017 10:18 AM
MrWizard wrote:
nothing simple about a crack in one of the side walls of a poly tank
it flexes with water level and can flex under stress while in motion
while screws, bolts, well nuts, may stop the crack from enlarging, they don't stop the crack from leaking
its a crack not a pin hole
โJul-06-2017 01:49 AM
Tom/Barb wrote:Ralph Cramden wrote:
Not glued in.........spin welded.SPIN
Just way too cool. gotta find some one close to do that.
โJul-05-2017 07:02 PM
โJul-05-2017 06:31 PM
โJul-05-2017 06:27 PM
โJul-05-2017 06:23 PM
โJul-05-2017 06:11 PM
โJul-05-2017 01:33 PM
Tom/Barb wrote:MrWizard wrote:
Poly tanks seldom get holes
What happens is they crack, usually in the side
One senario
Some body sticks the water hose in the fill spout and walks away
Comes back later water pourng out of fill spout
Tank gets over pressurized and cracks
Some people have sealed the crack with eternabond tape
And before someone says that won't work, they do advertise it for sealing fish ponds and pools
And yes those are usually done on the bottom of the pond/pool
So it's internal pressure helping to hold the tape in place
Klutz, drilled thru the outer bulkhead and drill 3, 1/4" holes near the bottom of the tank.
They now have plugs in them. I want a permanent repair. or it gets a new tank. but the pipe connections are glued in with something. What,,, is the question.
โJul-05-2017 12:37 PM
Matt_Colie wrote:
Tom,
While MDPE is not difficult to weld, it can not be done with air. You have to have a welder that uses at least nitrogen or some other gas.
โJul-05-2017 12:26 PM
One senario
โJul-05-2017 12:00 PM
โJul-05-2017 11:46 AM
One senario
โJul-05-2017 10:59 AM
โJul-05-2017 08:26 AM
