power gear jacks issue
TANDDANDBIGE
I have intermittent and not at all response from my Power Gear jacks. Power light is lit, no or little pump noise. Can anyone tell me where to find the control box? I have looked all over with no luck. I need to check connections, fuses etc. Any help would be appreciated. THX TB
2002 HR ENDEAVOR 40'
2007 FORD EDGE TOAD
6 REPLIES 6
TANDDANDBIGE
I still have not found it. However, by cycling the chassis battery disconnect off then back on it seemed to reset the controller and all is suddenly normal at least for now..... THX TB
2007 FORD EDGE TOAD
wa8yxm
The touch pad.. That is the control box
There is also a sensor box. roughly in the middle of yoru RV likely on the basement ceiling. Not easy to find
Check your parking brake indicator light on the dash. IF it is not on jacks do not go down.
gsf35099
My power gear controller is located in the bay area mounted to the bottom of the floor. Meaning you have to lay on your back and look up. I had to replace mine several years ago and retire the connectors as they had been knocked around and got damaged causing weird problems.
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
homerbw
I think it could be under the driver side dash. That is where mine is.
2000 Pace Arrow Vision 36B, F53, 275hp Triton V10
TANDDANDBIGE
Pump has power and will intermittently fire a bit if I jab the button, either front or rear several times. Acts like a bad connection, I have checked those at the pump; that is why I need to find the control box. THX TB
2007 FORD EDGE TOAD
Trigger_Happy
There may be an inline fuse right beside the pump.
2012 Discovery 40X 380hp ISC.
Toad is a 2014 Jeep Wrangler JK
