Question about 12V sockets not working
Snomas
I have two 12v plug in sockets on the dash of my Dutch Star and are only reading 11.1 Volts on my Volt meter. They will not run my brake monitor or TPMS monitor. My 4ea 6 volt coach batteries read 6.6 Volts. My Ford auto sockets measure 12.57 Volts and work the Monitors. What can cause this low voltage? Any thoughts appreciated.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
10 REPLIES 10
Snomas
Doug of Carrolton was right. It was a partially blown 20 amp fuse in the fuse panel on top of the dash.
I called Newmar to locate which fuse covers the 12 sockets and then replaced it. Newmar's fuse diagrams don't list which circuit the 12V sockets are on! Thanks Doug!
lanerd
Thanks John...I never knew that. Good info to know.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
wa8yxm
lanerd wrote:
dougrainer wrote:
=or partially blown fuse. Doug
Really? A "partially" blown fuse??? With all due respect, how is that even possible?
Think of how a fuse is made.. You have a thin wire usually inside a glass, ceramic or plastic case.. It takes TIME for the fuse to blow (In fact you can look up how much) fast acting fuses blow faster. Slow blow can hand in there for a couple seconds.
now... Imagine that the short only exists for 1/2 the amount of time it takes for the fuse to blow... It is only HALF melted.
(This is highly overly simplified but the point is that it is just shy of blowing when the sort is cleared or power is removed.
Page 2: that is not the O/P's problem however, he has a bad connection,, very bad if the voltmeter is enough to load it down a volt.
dougrainer
Snomas wrote:
I have the coach plugged in to the 120V house. The coach batteries are reading 14V and charging now. I will find the fuse. I checked the wires direct @ the back of the plugs and still get 11 Volts.
2 places the fuse is located
1. At the Shore Cord compartment on the back wall where the solenoids are. This is also where the Dash Radio fuse is located.
2. The fuse compartment in front of the LF tire. Doug
Snomas
dougrainer
Snomas...try attaching a separate piece of wire to the ground side of the 12v socket and ground it to the metal frame somewhere. Bet you will read the same or a fraction less that what the batteries read.
Good luck
Ron
Don't know "how" it happens. But I have seen it numerous times. The tungsten in the fuse "melts" but there is a charred sliver left and is enough to cause a voltmeter to read less than the supply voltage. When I get that reading, I then check the voltage on both sides of the fuse. I find that on the HOT side of the fuse I get the normal 12.8 to 13.6 volts and then that less than 12 on the "cold" side of the fuse. Doug
lanerd
Good luck
Ron
Ron & Sandie
TPMS: Pressure Pro
dougrainer
Newmar Dutch Star the front dash 12 volt plugs are usually connected to the COACH battery system and not the Chassis battery system. See if the 11.1 matches the coach battery voltage. A Defective ATC fuse can cause that type of low voltage when the main supply is indeed over 12.8 volts. If you plug in a 12 volt appliance, it will not work but the voltmeter will read the bleed thru the defective or partially blown fuse. Doug
fourmat
Also they have a habit of corroding at the power point in center disconnect power and clean
2009 Challenger
Dick_A
I would suggest looking for a bad ground connection from the 12 volt socket. A poor ground connection will allow some current flow thus the voltage reading. However, when a larger load is placed on the circuit, the high resistance will cause the voltage to drop.
2009 Tiffin 43QBP Allegro Bus
RoadMaster Sterling Tow Bar
US Gear UTB
Ford Explorer Sport Toad
WA7MXP
"Pisqually" the attack kitty :B
