Question on rear differential on 2010 Ford E350, V10
locster
How do I know if I have a standard or a limited slip rear differential? Is there a stamping on the housing?
We have a Coachmen 21QB that we bought used, and it doesn't come with a manual for the Ford chassis.
2 REPLIES 2
Terryallan
Does it have a door post sticker. There is a code on there to tell you. Read the axle code, then google it.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
gotsmart
If you don't feel like crawling under the MH then take the VIN to the parts counter at a Ford dealership, tell them you weren't provided any documentation on the chassis and would like to know:
1) what transmission that it has
2) the rear differential gear ratio
3) is it a standard differential or limited slip differential
Also go here. On the right side of the screen, enroll. Create an account. Add you vehicle's VIN. Get info, recall and TSB notices on the chassis.
https://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/HomePage
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
