Rear of Coachmen bottoming out.
dhanniford
I have a 2004 Coachmen mirada 30ft. It has a receiver hitch on the back and it bottoms out really bad on any sort of incline without the trailer even being hooked up. I'm wanting to get a bigger trailer and just curious what options i should look at to help/fix this problem. Thanks in advance for any advice.
5 REPLIES 5
RayChez
I used to have a Coachmen that had the same problem, until I discovered it had Firestone air bags on the rear springs. I added 90 lbs and the rear end dragging ended.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
atodalen
If you're talking about inclines when entering or exiting a driveway, try approaching them at an angle rather than perpendicular whenever possible.
Al
Al and Deedee
Spokane, WA
2008 Winnebago Sightseer 29R
F53 chassis w/ JMcKinley CHF and Brazel's UltraTrac rear trac bar
2006 Honda CR-V, Blue Ox Aventa LX, RoadMaster Even Brake
pkunk
What Brett said. Then, lighten up the back-less water, belongings, etc. Airbags to help the sagging springs.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
lawrosa
Is the angle of the trailer not level when hooked to the tow vehicle? Check that out...
The previous owner of my camper put wheels at the back for this purpose...They are heavy duty type wheels
I will try to get a pic...
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
wolfe10
First thing to do is get the RIDE HEIGHT SPECS from your chassis maker. Measure to see if it is within specs.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
