When I was washing the RV I broke the porch light lens it was pretty fragile. Most of my past RV's always had a amber lens this one was clear. I have heard amber attracts less bugs. Now is the time to change do you notice any difference between the 2 colors? I may just replace the whole light to a LED or at least change the bulb it doesn't light up.
LED is the way to go, but you don't need to replace the whole fixture ! I find that clear lens is much brighter !
2011 MOUNTAIN AIRE 4344, FMCA F334596, Cummins Power Play,Good Sams and KOA member..TOAD 2017 Ford Edge Titanium with a 6 cylinder Engine, License plate "TOWED" > RoadMaster Night Hawk Tow Bar and Base Plates. 😉
I haven't looked at the bulb maybe it is amber? I need to look the light over good I think I will get an amber lens and put in an LED bulb if the socket is ok.
9-11 WE WILL NEVER FORGET! FULLTIME SINCE 2010 17 DRV MS 36rssb3 17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch John “A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
