The Energy Manager will let you run both but it switches back and forth.
Now, if you do not have an EMS here is your basic hook up for the rear AC
Breaker box-----Transfer switch--generator---Transfer switch---AC
What you do is this.. "Break" the circuit after the generator and modify as follows.
Generator----Pigtail with 20 amp outlet 20 amp inlet, 20 amp breaker----A/C
Now use 12 ga wire to do this and get some 12GA extension cords... You may need to replace the outlet end.. I took a 40 foot cord and cut it 1/3 2/3. Since I needed a 15 amp outlet with pigtail for another job I cut the 15 amp outlet off, replaced it with a 15/20 put a 20 amp plug on that piece, put a 15/20 amp outlet on the other part.. Both are currently plugged into the park's 20 amp outlet (Which in this park has a 30 amp breaker) one feeding the REAR A/C and the other my converter. Nice division of duties.. So long as I use my head the breakers hold.
