I really have two questions. When using the auto disconnect, should you be able to insert the key in the ignition and start the engine without turning the main battery auto disconnect off? I can. Is that a problem?
Several times I have gone to start the engine and when I turn the key on, I get a click. Not at the solonoid, but somewhere under the hood. If I keep trying, it will usuallly start after two or three tries. I have replaced the starter solonoid relay and the starter ground relay. The battery, after driving the coach home(2 miles) was showing about 12.5 volts. Before replacing the relays, I had the battery load tested and it showed good. I just cleaned the battery terminals, not sure that makes much difference.
What would you be looking at next?
2007 Fleetwood Terra fyi.
2007 Fleeteood TERRA LX 34N
F53, 362hp V10
