Fatnjoe12's avatar
Fatnjoe12
Running rough fleetwood cornado
I'm new here so if this post is in the wrong spot im sorry
Just got a 92 motor home that has a 454 in it. Hasn't been run or started in 2 years. I've put seafoam and 15 gallons of gas in it. It will start east and run but you have to feather the throttle to keep it running. If you let off it will die. However if you spray starter fluid in directly it will stay running. Any ideas what to check. I asked on Chevy page and some said the idle control valve. I had a guy look at it today and he said it's not that. Motor has 37k on it. When it was running and I was outside by the exhaust it sounded like it was skipping a little.
