Jun-01-2017 11:39 AM
Jun-05-2017 06:26 AM
ArchHoagland wrote:
It doesn't boil out the top and the batteries are very clean. I've checked them with a hydrometer and all is well.
Jun-05-2017 06:20 AM
ArchHoagland wrote:
I check the 2 six volt house batteries about once a month and usually have to add some distilled water.
Jun-05-2017 05:36 AM
Jun-04-2017 11:35 PM
Jim@HiTek wrote:ArchHoagland wrote:
Mine is stored by my house and plugged in 24/7. I check the 2 six volt house batteries about once a month and usually have to add some distilled water.
Other than that everything else is fine.
I'm surprised you have to add water so often. A '04 Class A, especially a Monaco, I'd have expected that you would have a smart charger system in your Converter. But, sounds like you have a plain old charger, and it's running high voltage so it's boiling out water.
Couple things you could do...fully charge the batteries and then just disconnect the ground(s). They'll do fine (as long as they're healthy to begin with) over the winter, you won't even have to check them. You could disconnect from power.
Or, if you prefer to remain powered, try this:
Add 2oz of 3-in-1 oil to each battery cell. It's mineral oil, and it will keep the acid water inside the cell instead of it slowly bubbling out. So you won't need to add water as much, if at all. Also prevents corrosion buildup. Using mineral oil in flooded cell lead/acid batteries is a method used for over 100 years, even Edison recommended it.
Jun-04-2017 09:39 PM
Jun-04-2017 09:16 PM
Jun-04-2017 12:26 AM
Jun-02-2017 01:57 PM
Jun-02-2017 01:40 PM
Jun-02-2017 11:13 AM
Jun-01-2017 11:50 AM
Jun-01-2017 11:47 AM
