Shower/plumbing
edda
I have a 2003 Itasca Sunrise with very low water pressure in the shower faucet, all other area's seem to be okay. I replaces the faucet assembly to no avail, any suggestion's.
5 REPLIES 5
Jim
It the shower head is new, then it probably has a flow restrictor. Those cheap pieces of plastic can often restrict flow much more then intended.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
Cobra21
Most new shower heads have water saver piece in them. I take them out.
Also check the screen in the water faucet to make sure it's clean. By eliminating those two things, I would again look at the faucet valves.
Brian
edda
Shower head also new as for water filter it's located under the kitchen sink, plenty of pressure there.
boba
if you have a full house water filter, check to see if that is causing the low pressure.
Ranger_Smith
Shower head plugged maybe??
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
