โMay-30-2016 04:08 PM
โJun-07-2016 07:08 AM
SoCal Kevin wrote:
I recently noticed a leak from my kitchen sink. It was coming from between the sink and the strainer / drain. As I took it apart to fix it I found the way the strainer / drain was originally installed was with a thin rubber or plastic seal. The seal went the way of the dodo. As you can imagine after all these years, it was dry and brittle and not doing its job. I fixed it with some plumbers
โJun-06-2016 09:05 PM
xctraveler wrote:
We came back to our coach after two months of travel away. Turned the water back on and the kitchen faucet leaked steadily. Naturally this was Sunday morning of Memorial Day weekend and we were recovering from a a five our flight and three hour TZ change.
I turned off the city water and decided we would use the pump, only turning it on when we need water to reduce the amount of water leaked. it is 36 hours later and the leak appears to have stopped! I suspect a connector dried out and is now tight with the moist gasket. Will turn city water back on in the morning to see how it goes. Would love to fix it, maybe even replace the fixture, but it will wait for now. Need to service the engine and components and replace the tires, that comes first as long as the joint stays tight.
โMay-31-2016 07:36 AM
โMay-30-2016 10:17 PM
โMay-30-2016 06:57 PM
