Slide has gap at the top
Moffittclan
I've searched the forum and seen that this might be possible but any Damon Escaper's out there that can answer specifically?
I was hoping you could tell me if the slides are adjustable on the 2003 Damon Escaper. I have a triple slide. The galley seals tight all around but the bed and living room seal at the bottom but have about 1/2 to 1 inch gap the tops. Is there an adjustment bolt/nut that I can turn to level this out to seal tight?
Thanks for your help!
Mike
23 year Active Duty Air Force
Waiting to retire (when I'm done having fun)
Empty Nesting it starting Summer 2016
2003 Damon Escaper 40' 3 slides (my first Class A)
330hp Cat 3126E
2014 Jeep JKU (toad)
1 REPLY 1
BigBlockTank
Good news is, yes they are adjustable. Bad news is, in 10 years of working on RV's, I can't remember which room system they use, therefore, don't know where it is. Wherever it is, there should be a bolt and a lock nut to hold it.
I think if I was in your shoes, I'd find a qualified tech and have them do it. Then, you can be snoopy and find out what he's doing and ask questions. If it ever happens again, you'll know.
Once you learn the systems that they use, they're not so "magic" any more. If you decide to do it yourself, do it in small increments and check progress after each one.
Good luck!!!
