Generator not running correctly on full load
J-Rooster
There was a bad windstorm and power outage here in the Pacific Northwest yesterday. I fired up the genset and under a full load the genset sounding as if it was out of timing or sputtering? So I turned the furnace off and plugged in a small portable heater with the microwave on TV on lights on etc. and the genset ran like a top for 8 hours (until morning). I own a 04 Winnebago with heat pump/furnace. Has anyone ever troubled this problem? Thanks, Rooster
10 REPLIES 10
Jim
Most would recommend running that stuff called Seafoam through the genset. Remove the fuel hose and plunk it into a gallon of fuel with the Seafoam and run that. I had a propane Genset so never needed to clean the carb. Never gets dirty. So I don't know all the details.
BTW, I think you're suppose to run your Genset for one hour per week with a heavy load. That would mean you should have 624 hours on it. So, get crackin'. They're capable of 10,000 hours before major overhaul so try running yours more often. JMO.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
booty51
Will the Marvel Mystery Oil keep the fuel from going bad like a fuel stabilizer? I know this stuff has been around forever. I know it is a upper cylinder lubricate. Haven't read the back of a bottle in years.I looked up Marvel on line and refreshed my remembers about Marvel. May buy some and use it.
ksg5000
Furnace runs on DC/batteries - portable heater runs off of AC/Generator. Think you just upped the load rather than reduced it. At any rate sounds like you might have had fouled spark plug or gunk in carb which cleared itself.
Kevin
crasster
If it was mine, I would start by checking the plug and putting the suggest amount of marvel mystery oil into the fuel. It will clean the carb and the upper cylinder system of the engine. If it was dirty, you could get a bit more HP out of the engine thus more strength on the alternator during a full load.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
rgatijnet1
It could also be a deteriorating rubber fuel line from your gas tank to the generator. These fuel lines eventually will harden and crack which can leak air in to the fuel and cause the generator to run erratically.
J-Rooster
GPWayne wrote:
I would check the fuel filter and fuel pump, clean the carb and install new plugs. Did you check it under full load after running for 8 hours? (You may have gotten lucky and cleared the crud out.) Sounds like a fuel problem. I take it is a gas genny. Your situation says a lot for running the genny under load each month. No surprises when you need it.
Wayne, I think your spot on! My wife got up in the middle of the night, which I didn't know and shut off the portable heater and turned the furnace back on full load and the Genset ran fine for the next 4 hours. I forgot to mention due to the illness of my wife's Mom we didn't take the coach out for nearly a year! That in combination with I hardly ever run my genset it's 12 years old and only has around 40-50 hours on it! I have a hunch that the gas varnished up a little which was causing the fuel (gas) not to flow correctly to the carb. I agree with your logic about it being a fuel problem. Thanks Rooster
GrampaR123
How many hours on your generator?
J-Rooster
Ray, it's a ONAN 5.5 Genny made by Cummins. My coach is a top of the line gas Winnebago that I bought new in 2004.
GPWayne
Crazy_Ray
Could you PLEASE tell up what KIND of genny you are talking about Rooster????
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
