Slide Outs
Wilson123
My slide outs aren't working. The fuse is good. Any suggestions on what to look for?
22 REPLIES 22
WETSNAIL
On my MH the jack system must be on for the slides to work.
WILDEBILL308
Not enough info to make a good guess. What make/model year and what makes the slide out mechanism?
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
Patrol_65
Is the parking brake on?
Nathan and Linda
KF4GYL
2000 Winnebago Chieftain 35U Ford Triton V10 F53 Banks Power Pack
DiskDoctr
Is your electric/hydraulic/manual slideout motor running?
Running and notmsliding out is quite different from slide motor won't operate.
rgatijnet1
Ignition interlock?
robsouth
Check your battery first. Must have good charge or slides will likely not work at all.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Mr_Mark1
Hello Mr. Wilson, what kind of system is on your coach? Electric, hydraulic? Brand name?
If hydraulic, check the pump for the fluid level. Some have fuses at the pump (ours does not). If electric, make sure your house batteries are fully charged. Since you give very little information, with your system, you might need to make sure that the parking brake is fully engaged.
Try starting the generator, let it run for a while to charge the batteries, then give it a try.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
SteveRuff
The first check is always the pin. There is a pin that goes through a square rod turned by the motor. If the shear pin has snapped the rod turns but not the inside. I replaced mine three times before understanding I needed a grade 8 from Home Depot. What they have out is usually a 5 but they have 8's if you ask.
Both retired. Travel with Nicky the Schnoodle. Son graduated and is teaching high school math. We still love our 2006 34' Allegro Bay XB and have 50,000+ miles on her.
