Slide outs
mikemc53
We are looking at used coaches and have decided that we want at least one slide out but more likely two or three. Our trips will entail long stays at destinations so we like the added space. We owned a three slide TT two years ago (bought new and owned one year) so we know a little about them but owning the TT brought up the two question areas that prompted this post.
First, how common (or uncommon) are issues with slide outs? Have many folks here encountered problems or known of folks who have had problems?
Secondly, and this will sound rather simple to most of you but, when the slides are in during transport, do most coaches still afford access to bathrooms, kitchen areas, bedrooms, etc.? I know that coaches can be different but when we had the TT it was pretty much useless until the slides were out - couldn't get to much of anything. Obviously one of the advantages we'd like to have with a coach, is the ability to access areas while on the road. We have started looking online and it's really hard to tell from pictures exactly what is accessible when the slides are in.
As I said a while ago, I will be bugging everyone for a while until we move on this later in the year.
Thanks gang.
2021 Gulf Stream Conquest 6250 (Class C)
16 REPLIES 16
Rick_Jay
mikemc53,
Slides, like any other system on a motorhome, are subject to failure. Sooner or later, something likely will come up, minor or major, but most folks consider the added space they add to worth the price of admission. Some on here may even recommend to stay away from particular slide manufacturers. I won't comment on the slide in our manufacturer as Georgie Boy is no longer in business. Unless you're looking for 13+ year old units, Georgie Boy won't be on your list.
As to accessibility, that is DEFINITELY something you want to check out. At most shows, you'll notice they have all of the slides OUT. You want to see what the access is when the slides are IN. You are correct is that some units inhibit and even prohibit access to key areas and storage space. We made sure our rig had the access we needed when on the road. If you overnight at rest areas, Walmarts, etc., the general consensus is NOT to put out the slides, unless you can do so where they will not cause a problem to others in the area.
Good Luck in your search!
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
K_Charles
I would never have a TT that you couldn't use everything with the slides in. Our last TT had two slides in. Our MH has two slides and you can get at everything except three of the drawers in the bedroom.
