โSep-09-2022 12:46 AM
โSep-10-2022 05:26 PM
โSep-10-2022 09:57 AM
Yankee Clipper wrote:
In my 97 Coachmen, the HWH hydraulic pump had an in-line fuse to each acivator component 4 levelers and hte full-wall slide. When this happened to me, it was a 5-amp fuse that failed from moisture. The pump itself cut off when the fluid got under 50% to keep the pump motor from burning up.
As noted above, there was a strap style chainfall to manually retract the slide.
I was under the forward booth seat and hooked to a mount under the cabinet under the counter where the trash compartment.
HTH,
โSep-10-2022 07:47 AM
โSep-09-2022 10:28 PM
โSep-09-2022 06:36 PM
โSep-09-2022 04:12 PM
dougrainer wrote:
It is amazing the 97/98 Fleetwood Bounder owners manual has NOTHING about the Slide or Jack system.
โSep-09-2022 10:16 AM
MrWizard wrote:
Situation has been resolved,
The slide is apparently wired to the engine/chassis battery getting a full charge on the a battery has allowed it to work normal and be pulled in, it's now weather safe , for the coming rain tonight
โSep-09-2022 10:10 AM
โSep-09-2022 08:29 AM
โSep-09-2022 08:28 AM
โSep-09-2022 08:17 AM
โSep-09-2022 07:47 AM
โSep-09-2022 06:59 AM
โSep-09-2022 06:28 AM
