โMay-10-2017 05:25 PM
โMay-12-2017 07:18 AM
Kidoo wrote:msmith1199 wrote:
If it helps, just today I was scanning all my old receipts into digital format and I found the one where I repaired this exact same problem in 2013. I had it done at the Freightliner dealer (most expensive place) and they replaced the brake pads. Total charge was $294.90. I'd gladly pay $300 again over trying this job myself.
Do you have part number for the seal?
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โMay-12-2017 06:57 AM
โMay-12-2017 06:54 AM
DSDP Don wrote:
"Kidoo".....Your Cayman has drum brakes. Where are you seeing a caliper and disc?
Call this company.....they specialize in Monacos. They may have the seals, or at least the part.
Source
โMay-11-2017 07:25 PM
โMay-11-2017 06:57 PM
โMay-11-2017 05:16 PM
โMay-11-2017 03:17 PM
โMay-11-2017 02:44 PM
Kidoo wrote:
Thanks eveyone, I guess I will tackle this job myself. I saw a write up from a guy that made himself a tool to remove the wheel and the Hub, not as a whole unit but seperatly. I will replace the brake pad at the same time and check the brake disk, my galiper look ok but I might change it too, it is a 2003 and maybe time to replace it.
I just wonder what is the torque or adjustment for the bearings?
โMay-11-2017 12:48 PM
โMay-10-2017 10:20 PM
Kidoo wrote:
Hi, I have a 2003 Monaco Roadmaster R4R, Cayman 34, DP, and my front hub is leaking. I need a Part Number, any help appreciated.
Thanks
โMay-10-2017 09:01 PM
Thanks
โMay-10-2017 07:13 PM
โMay-10-2017 06:12 PM
