Sep-01-2013 07:31 PM
Oct-07-2013 04:16 PM
Sep-14-2013 11:52 AM
Sep-08-2013 07:14 PM
Sep-08-2013 05:19 PM
dengineer wrote:
Could you please describe in detail the location of the bolts or please post a pix?
I have a similar problem and would like to take the whole assembly put, I have looked but not found what you described.
Thank you for your assistance, I guess there are quite a few of us with the same inop step cover.
Agn tnx!!!
Sep-07-2013 10:31 PM
Sep-04-2013 05:30 AM
Sep-04-2013 05:19 AM
Sep-03-2013 07:43 PM
djbroughton wrote:Could you please describe exactly where those screws are for removing the entire assembly?
So I had a look underneath the coach and it is sealed up solid. However, I did find 4 screws at the entrance to the slide compartment. I removed these and the whole tray mechanism slides out as a unit, motor included....
Sep-03-2013 06:19 PM
djbroughton wrote:YC 1 wrote:
I don't think you can get under there. Run the motor until the mechanism is close to the front. Then pull the slides out to match. Looks like you already took the step cover board off. Hopefully you can drill it out and install some nuts and bolts.
Thanks but the motor doesn't run. I just get a "clunk" when I press the switch.
Dave
Sep-02-2013 07:29 PM
Sep-02-2013 03:58 PM
FIRE UP wrote:
djbroughton
Well, by the pics, I'm not sure but, your particular step does not look like it's air activated. It looks to be the same type mechanism that lots of garage doors utilize. And that's a large screw-drive operation. Again, not sure but, I don't see any air cylinder. Ours is even different from that and air operation. Ours is made by Kwikee and utilizes the same drive that the steps use for extending on the outside of the coach.
Now, without seeing any other details of your operation there, yes, one of the answers you've received suggested you re-attach the cross pieces that look/appear to be broken away from a structure. You simply have to determine exactly where they go, and then either re-attach them or, if they've broken off, that's going to be a problem. Trying to get into that area to drill out broken bolts could be one serious pain in the a$$. But, again, I'd have to see more detailed pics in order to advise some particular coarse of action.
There must be a Monaco diagram around some place on the net that shows that step cover system and how it operates. One more thing. I don't know about your generator but, ours is on a sliding tray and, If I move that gen all the way out on the tray 'till it stops, I can then climb under the coach, and sit up inside the cavity that the gen created and remove about a zillion screws and a plate that covers up the bottom of that entire step cover operation. Don't know if you have the same capability or not.
Scott
Sep-02-2013 09:41 AM
Sep-02-2013 09:32 AM
Sep-02-2013 08:55 AM
