Still not sure about putting Nitrogen in your tires?
Ivylog
If you have virgin ears you probably need to pass on the following video and the 10 reasons why Nitrogen in tyers is a SCAM. This Aussie presents some very good FACTS.
Virgin ears alert.
Upgraded with a 08 HR Navigator 45โ€™...
40 REPLIES 40
Rick_Jay
"It allows the tire pressure (50 pounds per square inch) to remain constant throughout the race regardless of the temperature, which can reach 200 degrees Fahrenheit."
time2roll wrote:
Apparently NASCAR is able to defy the laws of physics
I caught that too! I guess that's why the cars cost so much. ๐Ÿ™‚
As azdryheat stated, it's the lack of moisture in the nitrogen that should get the credit. NOT the nitrogen.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
azdryheat
time2roll wrote:
azdryheat wrote:
NASCAR uses pure nitrogen in their tires (from the NASCAR website): "The reason NASCAR tires are inflated with nitrogen, rather than the normal air we pump into our tires, is due to the increased stability under hotter temperatures that the gas exhibits. It allows the tire pressure (50 pounds per square inch) to remain constant throughout the race regardless of the temperature, which can reach 200 degrees Fahrenheit."
Apparently NASCAR is able to defy the laws of physics :R
Here's another take on it:
"Many race car teams use nitrogen instead of air in their tires because nitrogen has a much more consistent rate of expansion and contraction compared to the usual air. Often, a half pound of pressure will radically affect traction and handling. With track and tire temperatures varying over the duration of a race, the consistency of nitrogen is needed.
Nitrogen pressure is more consistent than normal air pressure, because air typically contains varying amounts of moisture due to changes in the relative humidity on race day. Water causes air to be inconsistent in its rate of expansion and contraction. So, a humid race in the southeast United States or a dry race in the desert western United States could make for unpredictable tire pressures if "dry" nitrogen were not used." (Source: How Stuff Works)
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
RLS7201
Thanks for the link. John Cadojan is a hoot. I spent most of the morning listening to his other rants.
His rant about octane is spot on.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
time2roll
wa8yxm
There are times and places, High performance race cars, Air and Space craft, where Nitrogen makes sense.
I use a mixture of gasses including Nitrogen, in fact it is mostly nitrogen.. It's also free, it is called "AIR"..
IN time, the concentration of nitrogen in the tire increases by the way.
Now on some car tires I do use Nitrogen,, but only when new, and only when the tire dealer puts it in at no added cost.
coolmom42
Regular air is 78 per cent nitrogen. Only in extreme applications like those above (super high pressure or temp) is there an advantage to pure nitrogen. Anyone who tells you otherwise is either trying to sell you something or misinformed.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Mr_Mark1
I had new tires put on several vehicles over the years at Gateway Tire in Tennessee. I use this company for new tires, tire repairs, batteries, etc.
They ONLY put nitrogen in the tires, no choice and they charge extra for it. They are so good about rotating tires for free and fixing flats for free that I don't really complain but I did question it.
Normally, regular air is just fine with me because the minute I use my own compressor to add air in the tires, the nitrogen that I paid extra for is diluted (somewhat).
Safe travels,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
crasster
Always thought it was a scam based on gut feeling alone. ๐Ÿ™‚ We are just talking about PSI here for tires. Just check them!
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
azdryheat
My only real experience with nitrogen filled tires was in the military. The tires on our fighter jets were filled to 300 psi with nitrogen.
The FAA requires nitrogen in all commercial aircraft tires to prevent auto-combustion when the tires become overheated.
But we're not jets nor racecars.
2019 RZR 1000XP TRE
rgatijnet1
In a perfect world, nitrogen might be OK but after the tire installer slaps a bunch of lubricant on your tires and then sets the bead with the shop air, the nitrogen that they put in afterwards is just adding to the already present contamination.
Using dry shop air is just as good for earthbound vehicles.
gbopp
I Don't need to watch a video to know it's a scam.
Unfortunately, dealers will continue to sell nitrogen to the unknowing.
I'm happy with the 78% nitrogen in my tires.
