I got the leak fixed!!! Made my day for sure! Here is what it was all about:
The leak was dripping on top of the grey water tank, which has indentations and insets on top. They would fill up with grey water and when the slide is brought in, the last motion is to lift the back up as it seats. This would cause the waste to flow off the top of the tank into the waste dump bay.
To find it, I bought a turkey baster and through the laundry bin I had access to the top of the tank. I sucked out over two gallons of grey water, just off the top of the tanks! I then removed the two drawers to the left of the sink and could reach in and feel the flex hose down to where it attached to the top of the waste tank. Letting the water run, I could feel it dripping out at the point the flex hose attaches to the black plastic fitting on the top of the tank. The drawer holes are really too small to work through, so I removed the shelf under the sink and the panel in the back left side. After positioning the slide in the right position, the leaking fitting was accessible through that panel. I verified visually that that is where it was dripping from.
It turns out that the male end of the flex hose screws into the black tank fitting. I think over time with temp swings and the slide moving in and out, the threads slowly backed out. I tightened it, and the leak stopped. WHat a relief that I didn't have to go out and try to find parts! Put it all back together and now I am back on vacation.
I'll add some pictures I took when I can get them loaded.
Thanks for all your help!
Jeff
Jeff
Retired AF, retired contractor, really retired!
2007 Winnebago Journey 34H 350hp Cat
2005 Jeep Grand Cherokee Toad with Air Force One
