Success with AC coil cleaning
AikenRacer
Pulled off the covers on our 3 ac units on the roof. Utilized some plastic sheets, duct tape and towels to seal off the opening to the mh interior. Spread out tarps over our bed, etc. that were located below the interior ac openings and set up my shop vac on the roof. Cleaned all 6 coils on the roof, 2 on each unit. Sprayed with the coil cleaner from Lowes. Rinsed with a water hose and at the same time had the shop vac running to suck up the rinse water. Worked really well. Only a small amount was caught by the interior tarps. Rinse water was awful. Can't believe how dirt the coils were. Got a $20 rinseable air filter from Lowes, cut to fit my intakes and now have a much better filter system. No major decrease in air flows. Will keep closer check on our system, they will never get that dirty again. No real problems, just took some time and very careful work on top the mh.
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
15 REPLIES 15
folivier
Just did the same but just laid a towel on the floor in case. I used a 1 gallon pressure sprayer with water to rinse and sucked up the water with the shop vac. No water got inside.
