Thor Vegas/Axis widespread E-350 Transmission Cable problem
jolooote
Googled it and found that there is a bad problem with the Transmission cable laying against the rear end of the HOT exhaust manifold and burning thru. It will not allow the transmission to be shifted into Drive when damaged. Look under the MoHO inside the frame member on the drivers side. If barely touching or close total damage may not yet have occured. Strap it away from the heat. Call Ford. Do NOT let them tell you its a Thor problem due to chassis lenghthening. That has nothing to do with this area. :E
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
7 REPLIES 7
jolooote
Took it to the local Ford dealer. Thay took care of replacing the cable under warranty with no hassle at all.
Joe & Charlotte
charlysmom_dad
jolooote wrote:
Its a Ford E-350 van chassis problem not necessarily a Thor problem?
That's my understanding also.
2015 Thor Vegas 24.1
jolooote
Joe & Charlotte
tderonne
Clicky
Tim
2004 Winnebago Adventurer 31Y
Ford chassis
charlysmom_dad
Absolutley. I wanted to give the link because there doesn't seem to be much discussion on this forum about this problem. The thorforum duscussion has a few pages & pictures. It's scary to think this could happen & there's no recall.
jolooote
Not everyone is on that Forum so I thought I'd share this important(Ford E350) problem here also.
Joe & Charlotte
charlysmom_dad
There was a discussion of this the thorforum: http://www.thorforums.com/forums/f8/e350-wont-shift-out-drive-2308.html
