Aug-07-2013 07:05 AM
Aug-07-2013 07:47 PM
Pass42 wrote:
also....Get Grade 8 Hex Nuts....they will either have 6 lines on the face or a dot & a dash on the corners of the same wrenchpad......most stores will sell you graded bolt with grade 2 dead soft nuts.......
Aug-07-2013 06:31 PM
Aug-07-2013 03:16 PM
rgatijnet1 wrote:
Be sure to use grade 8 bolts to fasten the body to the frame, instead of some cheap bolts that you can by at Home Depot. Sounds like it is basically an inexpensive fix, which is always good.
Aug-07-2013 11:53 AM
Aug-07-2013 11:39 AM
Aug-07-2013 07:40 AM
Aug-07-2013 07:24 AM
Aug-07-2013 07:14 AM
