Tire coating
GHOST1750
How many of you use something to blacken your motor home tires, if you do what do you use. I understand some of the blackening causes the tires to dry out and crack.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
19 REPLIES 19
harold1946
X3; 303 is the best protectant I have found. Makes the tires look nice and is rated at SPF 40 to help protect from UV. Been using it since 1993.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
wa8yxm
I use no tire treatment. Many do more damage than good
Best thing for a Tire is "rolling, rolling, rolling" down the highway under load.
garyemunson
X2 on the 303 Aerospace. Used it for a LONG time. Since using tires past 7 years is dangerous, keeping the tires clean and sprayed with 303 will keep them looking so good people will question why you are buying new ones (at 7). Have never covered my tires and they always look as good (or usually better) than ones that have been. You will not see cracks on your tires before 7 years (can't attest to beyond 7 since I will not keep them any longer than that) if you follow that regime. I question the 'rotting from the inside out', I think the deterioration is equal throughout the rubber..just comes with age. Rubber begins to deteriorate the moment it is made. Little cracks on the surface mean nothing and are just from ultraviolet sun damage that the 303 will prevent.
happy-2
I cover my tires,I wash my tires and wheels then cover them. A friend of mine who owned a Tire shop Told me its not needed to spray the tires, its just for looks BECAUSE Rubber tires Rot from the inside out. I cover the tires and Park on Rubber Mats to keep off concrete.
Trackrig
Aerospace 303
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
