tire size
duanebowman1
I have a 1988 skyline 26 ft motorhome. the current tire size is 235/85r/16. I want to put 245//75 r /16 c an I do this. rv has dully's ford rims- please help duane
2 REPLIES 2
Roger_Ohio
Response deleted by author. Safe travels to all
I'm outta here
Beverley_Ken
On check with the Michelin website, both sizes have the same load capacity, but the 245/75 have a smaller diameter which change your speedometer/odometer readings, but the biggest concern would be the additional space (almost and inch) required between the rear duals, to prevent kissing or rubbing between the two tires.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
