Tow Haul mode
ntar827
Have a Chevy Class C.
Do you normally drive with the tow- haul engaged or not?
Does it help of hurt on downhill grades?
Thanks
Nick
18 REPLIES 18
rvten
jdog wrote:
I think some are confusing "Tow Haul" with the overdrive lock out button on the gear shift of E450 motorhomes. I don't think that many E450 Class C motorhomes even have "Tow Haul".
No Tow Haul is standard on 07 and up on a E450.
Only use mine going down hill and exiting the interstate off ramps. Saves the breaks.
All it does is change the shift range.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
Mich_F
Rolin wrote:
If memory serves correctly:
E350/E450 chassis 2004 and below had O/D button (overdrive lockout)
E350/E450 chassis 2005 and above has Tow/Haul and the five speed transmission
As previously stated Tow/Haul on the Ford changes shift points, prevents gear hunting, and on down grades if you tap the brake it will automatically downshift to a lower gear to aid in braking. Some times I find it a little too aggressive on the downshifting.
That's how my 1997 E350 and 2013 E450 are.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
M_GO_BLUE1
When towing ON...when not towing OFF
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
jdog
My 2006 Ford E450 diesel chassis does not have Tow Haul. It has an overdrive lock out button.
Rolin
jdog
There are 2 different buttons for Ford E450. One is for O.D. lock out while the other is Tow Haul. They do not exist together. E450 diesel motorhomes do not have tow haul. Overdrive lockout and Tow Haul are 2 different things. Tow haul changes shift points and trans pressure. Overdrive Lockout only locks out the overdrive.
jdog
derh2o
Update to a previous reply. On my 2011 E450, i also use the T/H mode when i am not driving on a freeway. Due to the weight of these vehicles, i consider us as always "hauling".
Dean & Melinda
2011 29' Monaco Montclaire
2012 Ford Focus Toad
luvztheoutdoor1
I use mine when towing or hauling. lol
Linda
Scout, 10 year old Husky/Shepherd
2011 Jayco Greyhawk 26DS
NWnative
Use mine all the time. The E450 Drive train is hauling around a lot of weight with my particular set up. It reduces gear hunting and keeps the transmission and engine speed where it's most efficient. It also helps when descending a grade. Your manual will provide a recommendation for how it's designed to be used. Some of the smaller units would probably be fine not using it but, on the 30 footers, I am thinking that using it would be an advantage.
2019 Ford F250 Lariat CrewCab Short Bed 4x4 - 6.2 Gas w/4.30 Axle
2016 Airstream Flying Cloud 30RB / Blue Ox Sway Pro / Rock Tamers
2021 Mazda CX-9 Signature AWD
tenbear
rjstractor wrote:
Like has been said, it depends on the model of transmission you have. In my 2005 Chevy 2500HD (same transmission as the same year C motorhome with 6.0 V8), tow/haul changes the shift points for better towing performance. It does NOT keep the transmission out of overdrive but it will drop into 3rd more readily. It does nothing on downhill grades. Newer models like the 6L80E have grade braking.
Sounds like mine. 2004 Chevy Express 3500HD, 6.0 V8.
2010 Subaru Impreza Sedan
rjstractor
2017 VW Golf Alltrack
2000 Ford F250 7.3
dan-nickie
powderman426 wrote:
I can't speak to gmc, but on Ram trucks, the T/H mode is different by year. My friend has an 04 and T/H keeps it from going into overdrive while my 05 is the opposite. I would try to find someone with the same year. JMO
Good point.
At least the same make.
Dan and Nickie
2014 Forest River Berkshire 390RB
derh2o
I have an E450, so our tranny may be different. It also depends on the year of the vehicle. I use our T/H mode on our 2011 year primarily as a method of slowing down the vehicle. whether going down hill, or pulling off the freeway. It works like an engine brake and saves on brakes. I have not seen any value when going up hills, but if someone sees a value, please let me know.
Dean & Melinda
