towing a jeep tj
another_rookie
I have a jeep tj that recently had a 3" lift installed. With the new lift the jeep has what they call body roll. Wondering now, how will the jeep react when being towed by my motor home? Anyone here tow a lifted jeep?
Am new to this but have been reading and learning, one Motorhome I've yet to hear about is the R- Vision, I'm looking into a 2002 33' any thoughts on this Motor Home would be appreciated.
12 REPLIES 12
FIRE_UP
Jim & Betty wrote:
I have a small lift and it did not affect the body roll but there is one thing that does if the anti-sway bar is disconnected you will experience a very unstable ride. Just for grins check the anti-sway bar to see how it is hooked up.
My stock anti-sway bar was used after the lift using the sway bar disconnect kit from a well know vendor whom I can not rember (CRS kicking in).
JimR 1999 Jeep TJ behind a 40 foot DP
JimR,
You make some good points and, validate what I stated earlier. There are lots of variables. And that includes a whole plethora of aftermarket parts which, include sway bars too. I have what's called the Curry Anti-rock sway bar. Talk about JUNK! It's no where near as strong as the stock sway bar. But, it was Curries attempt at a "do-all" sway bar. That is, if it's installed correctly and, connected to the supplied links, they (Currie) try to establish a fact that there's no need for disconnecting their sway bar due to the fact that there's enough flex in it that it won't inhibit off roading.
But, they also claim that there's enough strength in it that, it will suffice for good body control during road operations. HOGWASH!!!!!! The designers at Jeep/Chrysler, worked pretty hard on setting up the original Jeeps suspension to make it as safe and road worthy as possible. And so, the design, thickness and strength of the factory sway bar is quite stout.
So, if the OPs Jeep has an altered sway bar, or one like mine, I can surely see where his concerns are generated from.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
Community Alumni
Not applicable
FIRE_UP
Well,
First off, earlier Jeeps SUCKED in quality of ride in the first place. CJs were as close to CAVEMAN operations as possible. Any lifting and alterations, REALLY made them worse. YJ models, were only marginally better as, they too still had leaf spring suspension which, is a poor suspension operation anyways.
Then the "TJ" came along. That was a LIGHT YEAR advance for the Jeeping planet. It sports a coil spring suspension which, is phenomenally better than leaf springs. But, being that it's STILL A JEEP, and, even with that kind of suspension, it's still rides marginally better than a rock.
I say that because, as many of you already know, there's only a few ZILLION cars/trucks/anything, that rides much better and more civilized than a Jeep out there. But, based on the numbers you see on a day to day drive in America, zillions of people use them as daily drivers. And, when modifications take place, most of the time, the somewhat average ride of bone stock jeep, goes down hill from there.
So, if the OP is Jeep-wise, he will realize that, while not as stable and "agile" as bone stock can supply, a lifted one will work and, get him down the road, with moderate changes in quality.
I personally have never even sat in a "JK" Jeep. I've been told that they ride even better than the TJ. Someday, we'll take one out for ride and see for ourselves, if, any improvement is realized over all other Jeeps we've owned.
Now, if you're not used to Jeeps and, the operational characteristics, and, you purchase one that is BONE STOCK, and get accustomed to it's ride then, MODIFY IT BY LIFTING IT, even moderately like 3" lift, you may think you're sitting on the moon and, are riding dangerously sloppy.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
chuckftboy
I've towed a TJ with a 4" lift for 10' of thousands of miles and always have to use the camera to make sure its still behind me. Body roll? Guess I have it too but never noticed it much.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
mdprince
We've towed our TJ since 2004. It has a 4.5" lift and 36" tires. Never a problem as it still corners better than the DP. Just make sure your tow bar is parallel to the road.
2006 Revolution LE 40E
2004 Jeep Rubicon Toad/Brake Buddy or
20' Toy Trailer/Quads 'n Dirt Bikes
FIRE_UP
Thanks for your guys answer, my jeep looks just like yours Scott. Scott, does your jeep have the " body roll" when going around corners? I have never driven another lifted jeep other than my own.
Frank
Frank,
It's a GIVEN that, when you raise the "CG" or, Center of Gravity of any automobile/truck/Jeep/ etc., you change it's operational characteristics. The designers and engineers that created the Jeep products, did and continually do, make them considerably safer and more efficiently operating machines. But we, in the Jeeping REAL world, continue to "Undo" those engineers work by lifting them, putting larger tires on them, and installing a whole bunch of aftermarket parts.
Well, after owning and operating 8 different Jeeps with a zillion types of parts, lifts, tires, and anything else, no one's died yet.
So, to answer your question, "body roll", after a lift is almost a given. Just how much roll you get, in both daily driving and, off road, all depends on how the Jeep was setup for both operating conditions. If done correctly, (and the term "CORRECTLY" is subjective in the Jeep world) and if the shop or person that did the lift has experience and knowledge of what's needed to be done to preserve good ROAD MANNORS, but, yet allow for quality off roading too, then body roll will be kept to a minimum.
The primary component that protects against body roll in both stock operating and modified vehicles is the SWAY BAR. If, that sway bar has been changed and or modified of it's original operating geometry, there is a high possibility that you will experience your "body roll".
The stock one can be, and often is, used again, even with many forms of lifts.
So, hope this helps some. Good luck.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
zman-az
Had a 4" lift with 35's. Now at 3" with 33's. I beat the **** out of this jeep. Been thru death wobble couple times as parts wear out or break. Have to keep up on maintence for it to tow nice. As far as side roll doubt that wil be a issue towing. You can always upgrade front sway bars if needed. I think the biggest concern is dw. Your parts need to be in great working order and you must have the front end properly aligned by someone that knows how to align lifted jeeps.
Steeljag
Off topic, but your Rubicon looks good!
AR - if you have not, check out the Jeep Wrangler Forum for questions / answers on all Jeeps. Tons of info over there!
BTW....do you have what's needed ( tow system) to tow your jeep?
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
Twomed
Circus Circus...been in that spot ๐Ÿ™‚
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
another_rookie
Frank
Trackrig
I've got a 1-1/2" to 2" lift and it tows fine.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
FIRE_UP
Another rookie,
Your new jeep, with its 3" lift, is very normal in the Jeep world and, also is very normal for many RVers that tow them. Many have lifts that are double that. I did for several years and towed it all over the western U.S.
Your "Body roll" is nothing to speak of. Sure, it's not as stable as it was when it was sitting at bone stock height but, it's not anything to be concerned about, especially when towing it. As stated, we towed our '04 Jeep TJ Rubicon with a 6" lift and 35" tires, all over the planet and, had absolutely ZERO issues doing so. We had no accelerated tire wear, no front end component wear, no DEATH WOBBLE, no ill-handling effects of the motorhome due to having that 4800 lb. Jeep tied to it, NOTHING!!
If you have any issues, with hooking things up, ask away, there's lots of experienced Jeep towers on here. Good luck.
Scott
P.S. Below is a couple of pics of ours. The Yellow Rubi we had a few years ago. The Red Rubi is one of our present toads and it's sporting a 4" lift with 33" tires.
Scott and Karla
SDFD RETIRED
KI60ND
