Hey guys I just bought a 97 Dodge Coach House Class B Van. I requested my mechanic to change the trans oil and axle oil.
I had to use the original mopar transmission gasket from dodge because the felpro gasket I got from oreilly did not hold the oil in the pan and it was leaking out. The felpro gasket was a thin rubbery gasket as opposed to the thick plastic mopar gasket I got from Dodge dealership. My mechanic changed the rear axle oil and I gave him the white silicone rtv sealant I bought from dodge to seal the rear axle from leaking. Dodge said a gasket is not required for the rear axle. Dodge told me to use the rtv sealant instead. After parking my car overnight I noticed some fluid on the ground around where the rear axle is located. I beleve the rear axle is leaking fluid. It could possibly be the the lugnuts on the rear axle were tightened to much or not to tight.
1989 COACHMEN FORD ECONOLINE 250, 2ND OWNER, VAN FROM LAS VEGAS 44000 ORIGINAL MILES MINT CONDITION MORE PICS ON MY FACEBOOK MARSHALL KHAMOU
