Tv access 2015 Tiffin 37AP
5thhand
Trying to set up cable. How do I get the mid coach tv off the wall to access plugs?
5thhand
4 REPLIES 4
Big_Jimmy
2011 Tiffin 32CA Just pulled center TV out and installed a HDMI cable and it was 2 screws (left side) lift and comes right out.
wa8yxm
Very likely you don't bother.. Assuming nobody has messed with the wiring (They often do to re-purpose the park cable lead for sat tv) you should have a cable TV fitting on the "Services" side (Driver side) of the RV. likely near your electrical connections..
Inside the RV you have a wall plate.. Likely says "Winegard" on it (But may be different)
It will have a Switch. a Light, a 12 volt accessory outlet (nearly useless.) and an antenna connection. the main TV may be hooked to it.
Turn the light off and park cable is selected.
Most folks say this is the Over the Air antenna pre-amp (NOPE it is not the pre-amp is a "mast head" type inside the antenna itself where belongs) The wall plate is the power inserter (Sends power up the coax to the amp) and a switch (Park Cable/OTA) and a splitter (Up to 3 TV's depending on the plate model)
No need to pull the TV and rewire
It's already wired
Exception.. If you need a special set top box....
IN that case the best place to splice it in is teh wall plate (Assuming all TV's same program)
Remove from wall there are 3 or 4 cables on the back.
With cables DOWN the 2nd one is "park cable in) (Middle if there are 3) unook it and using a double female (Barrel) connector extend to the set top box and the RV out from the box back to the port on the switch.. Assuming the box has RF out.
OTherwidse a photo of the TV and we can likely help you access.
older_fossil
If it is mounted like our 2016 37AP, there are (four?) screws holding the bottom of the TV mount just below the TV itself (kinda hard to see on ours). With these removed, the bottom can swing out and the TV mount with TV lifted off the top.
HTH,
Art
Art & Barbara
2016 Tiffin AB 37AP
2011 Jeep Grand Cherokee
MountainAir05
it either lift up or slides either way and then out of the sockets. You will have to look behind at the mount.
