TV problems
95impala
I am a newb to class A world and recently bought a 2007 Hurricane 34B. It has tube TV's front and back and has what I believe is a Winegard control unit as well as digital convertors. I can't get the rear tv to work at all, only static and the front pulls is intermittent. I have no manuals and could use some advice.
Thanks in advance.
16 REPLIES 16
RedG
If you're trying to watch cable, you need to turn off the green light on the Winegard panel. If you're trying to watch off the air tv, you need to be sure the green light is on.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
USAFBILL
I would check the coxal cable connectors, especially the one in the bedroom. Those that connect to a ceiling junction box. Sometimes the cable center lead will back out of the connector and result in loss of signal.
Good Luck
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
