Upgrading Solar
obiwancanoli
Re: Solar Panel upgrade - Is it necessary?
I have a 10 Watt Chassis panel, and also installed another 160 Watt panel to extend my ability to rely on coach power for an extended period. Not sure where "extended" falls, but plan on making full use of it as circumstances require.
Thinking it might be prudent to add another panel or two, but looking for rationale, pluses and minuses, and experienced input from fellow RV'rs...
Appreciate your input, thank you!
7 REPLIES 7
obiwancanoli
Lwiddis wrote:
Adding one or two 160 solar panels may exceed your controller's capacity. Check it before buying more panels.
I have one 160 watt panel (8.7 Ah), and have purchased two additional panels (26.1 Ah total) to align with my 30A controller, and given what I think my needs will be, I'm adding more than I need to deal with any miscalculations and/or conditions changing the dynamic.
Just have to find an installer, and will be good to go.
AllegroD
and it depends on your controller. You could upgrade it as well.
Sam_Spade
I think it is prudent to NOT spend money on things until you actually know that they are needed. That is, don't "solve" a problem that doesn't really exist.
Assuming that you have a good generator on board, you might be just fine with what you have now.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Lwiddis
wallynm
Read this thread
Solar
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Ed_Gee
2oldman wrote:
Depends on your power usage.
Yes. And also depends on the size of your battery bank. No need to get more solar power than needed to charge whatever AH battery you have.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
2oldman
