Upgrading to a 10,000 reciever?
palehorse89
I have been searching the threads on here looking for info. on upgrading my 5,000# receiver on my Spartan MM chassis to a 10,000# rating for the purpose of towing a enclosed trailer. My Spartan chassis has a 10,000 GCWR, The Newmar sales Boucher states that it came with a class 2 receiver w/5,000# weight rating. I have read were some have had a weld shop "beef" their OEM receiver up, and others that have bought a new receiver rated at the 10,000#. Through out my search's I have not found anyone that lists a 10,000# receiver for a Spartan MM Chassis specifically, Where does a person find a higher capacity receiver that will bolt on to my Spartan chassis?
Any Idea's? Where does Spartan buy the receivers for their chassis? I think some of the late model chassis have come with 10,000# receivers(or higher) from the factory now?
My specs from Newmar = GVWR - 31,000# GCWR = 41,000#(I am under the GVWR)
2000 MADP 4060 MOUNTAIN AIRE
350HP ISC, 2011 JK SAHARA,2006 ULTRA CLASSIC,1989 FXSTS
38 REPLIES 38
wa8yxm
I think I answered this elsewhere.. You said the chassis has a 10,000 CGVW rating (you may have put it in a different order) This means the Motor home and trailer, combined, loaded, must not weigh more than 10,000 pounds.
How you can do that and still overload a 5,000 pound receiver I do not know, I know I can't and my CGVW rating is 26,000.
Or did you mis-type.
MikeRP
I just upgraded mine from a 5000# to a 7500# receiver. It was no big deal.. Forest River had a replacement.
Here's a link I found: http://www.spartanchassis.com/cps/parts_mh.asp
Good luck!
palehorse89
JimM68 wrote:
You're 10k receiver won't be bolted on, it will be welded on, most likely a the 5k receiver is too. Take it to a truck frame shop, they will know how to handle it.
My 5,000# receiver is bolted on w/4 large bolts now......hoping that the new one will also bolt on, see no reason to weld....
JimM68
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
dougrainer
ANYTIME you want to upgrade a 5000# to a 10,000# you must have a welder beef up the rear frame mount area's. The RATING on the chassis hitch has nothing to do with the GVRW, it has to do with how strong the rear hitch mount is. Lots of people have added a 10,000# in place of a 5000# after having the rear frame beefed up. Doug
wallynm
Look in the Newmar yahoo group files.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
topflite51
I personally would call Spartan for that info.
:CDavid
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to fish
Simply Despicable 😛
Any errors are a result of CRS.:s
BarneyS
Moved to Class A Motorhome forum from Towing for better response.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
VintageRacer
Mostly the receiver isn't the issue, the frame is the hurdle. It does no good to add the largest, heaviest receiver if the frame you attach it to is too weak. My advice is to consult a truck frame specialist, they extend and modify truck frames all the time and they will know what to do.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
