Very slippery shelves - need help
alharms
We just purchased a Melbourne 24L and we are having problems keeping the items in the overhead storage units staying in place. The shelves are very, very, slippery like they have some kind of finishing oil on them. We have tried using alcohol to remove the oil substance to no avail. We have tried using non-slip shelf liner or the rubbery type shelf liner and still the items slide all over the place. The shelf liner slides with the items because the shelves are so slick. Any ideas?
16 REPLIES 16
ron_dittmer
Try two faced carpet tape. It might not stick, but then again it might. I used carpet tape to hold down our foam shelf lining material. It works great for us.
sullivanclan
We use both he shelf rubberized material and small baskets of different sizes. All part of RVing I guess.
2003 Ford 450 Jayco Greyhawk 25D
1986 Jeep Renegade
2011 Jeep Unlimited Rubicon JK
cencerrita
non slip matt supplied for ships/yachts is great. Go tot a ships chandler if you can not find on amazon etc. Used it for years at sea and you do not have to glue it down and things stay in place.
https://www.amazon.co.uk/d/1b3/Prima-Roll-of-Anti-Slip-matting-1-5m/B004AXTIYM
www.cencerrita.comNow living in Pembrokeshire, Wales, UK. See our web site for US travels and books www.cencerrita.com
alharms
Wow! Thanks to all who replied. We are going to try the tacks in the corner first on the rubber shelf covering. If that doesn't work...then the spray adhesive. Thanks again.
Bordercollie
Sorta related subject, we take the round glass thing out of the microwave and store it between the overhead bed cushions. Had one come out of the microwave door, fall and get broken.
pnichols
Here's a warning ... non-slip shelf surfaces are not the only thing to change.
MAKE SURE that the doors that close to hold the stuff on the shelves have something to keep them closed beyond their latches that come installed. We've had these doors pop open when traveling twice with disastrous, messy, and potentially dangerous results. We now keep these doors shut with (in one case) double stock latches and (in the other case) with bungy cords in addition to the single stock latch.
2005 E450 Itasca 24V Class C
Photomike
Like others have said tack it down or you can get a can of 3M adhesive and spray the shelf, let it dry and it will add a rougher tacky surface. I have done this by accident in my garage when working on projects and the over spray creates a rough surface on the workbench.
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
path1
We used to have same problem. Wife talking with her sister. Her sister works at bakery and delivers wedding cakes. After losing a couple and trying different stuff they have had best results with this link. And they (DUCK brand) might even have some heavier duty stuff. Looks just like normal stuff until you compare side by side. Much more robust. Read reviews.....
https://www.amazon.com/Duck-1100731-Non-Adhesive-12-Inch-20-Feet/dp/B002AS9NAI/ref=pd_sim_79_5?_enco...
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Stormy_Eyes
Matt_Colie wrote:
We pinned the non-slide shelf liner to the shelf at the corners with push pins. This is easy to do and easy to pick up and clean.
Matt
Like Matt, I'd suggest you rack down that nonslip shelf liner. Benice you already have the liner, it should be easy to do...push pins or staples or strips of lath at ends or whatever fastening method works for you.
samven1
I used thin cork tiles that have a mild adhesive on the bottom because I thought it would stop sliding and quiet things down but I found out that if the bottom cant move the top just falls over. I ended up with bins that fit snugly and hold all the items. And its much easier to just pull the appropriate bin down to get the smaller things rather than trying to dig behind things that have shifted.
Sam
03 Dodge Ram 1500 QC LB Hemi
2015 Four Winds 22E Chevy
Matt_Colie
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
DutchmenSport
Use small baskets to hold items in place. Once you fill the cabinet with the baskets, smaller items won't spill all over. We use plastic tubs, tupperware style tubs, Gladware type tubs, and even a couple wicker baskets in all our cabinets to hold things in place. (especially the meat seasonings).
It's funny traveling though. I have on occasion left a single item, like a salt shaker or a can of cola on the kitchen counter top. We travel for a couple hundred miles, and it never moves. Yet, inside the cabinets, things shift around, door pop open, and things slide across the floor. Just doesn't make sense sometimes.
DrewE
Maybe apply some grip tape such as is used on skateboards etc.?
Trackrig
This is sort of a drastic action, but apply Anti-Slip safety tape that comes in 4" wide strips from Amazon.
Amazon safety tape
Or go to a commercial paint store and they should have crushed walnut shells. It only takes a little bit of it added to whatever you want to repaint the shelves with.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
