video wiring upgrade?
JimM68
It's time to look into upgrading my audio/video in the main cabin.
Coach is a 2008 monaco knight 40skq.
It's a reversed layout front kitchen model.
The TV is on the back wall, above a fireplace.
Sat receiver and DVD/surround sound player are up front over the drivers seat in the overhead console.
I have 2 sets of RGB/LR component RCA cables going from the front to the TV.
I'd really really like to have HDMI...
Does anyone have a clue where Monaco ran these cables?
And how much coach has to be taken apart to get at them?
I can see that bundle of coax as thick as my arm vanishing down into the cabinet that the fireplace is in...
The raised rail frame area in the basement is completely sealed off...
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
50 REPLIES 50
Larry-D
x2 on the wireless HDMI. Works great, repeats the signal from the Dish Network remote and there is no interference. The only downside is that it is limited to one wireless receiver, supposedly by the FCC - something about "broadcasting".
crasster
You can run HDMI almost through anything, just depends on your route. Sometimes it helps to run wires under the floorboards and/or under the coach. I'm actually surprised that a 2008 didn't come with HDMI.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
janstey58
msmith wrote:
Before I did so I went and looked at a bunch of new motorhomes and trailers to see how most were hooked up with the newer HD equipment, I found almost all had their TV's hooked up with RGB cables. I found very few HDMI cables. But that was two years ago so maybe they've upgraded now.
My 2015 Fleetwood DP has HDMI throughout the coach to all TVs.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
sch911
Forget the existing obsolete cables. Look into wireless HDMI. I have a i/o Gear system that works exceptionally well.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
msmith1199
I have ducted A/C and I ran an HDMI cable through it to the TV in the bedroom. Worked great. Before I did so I went and looked at a bunch of new motorhomes and trailers to see how most were hooked up with the newer HD equipment, I found almost all had their TV's hooked up with RGB cables. I found very few HDMI cables. But that was two years ago so maybe they've upgraded now.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
MrWizard
Moderator
Moderator
Most likely you can do nothing about replacing the coax with hdmi
If you have heating a/C ducting in the ceiling, you might pull hdmi thru the duct work
Most likely your best option is hdmi over coax converter
A module goes on each end of the coax
The HDMI signal is converted to digital rf , transmitted over the coax, and converted back to hdmi on the receiving tv end
https://www.google.com/search?q=hdmi+over+coax+converter&oq=hdmi+over+coax&aqs=chrome.1.69i57j0l3.22...
I can explain it to you.
1997 F53 Bounder 36s
