Water in Diesel Tank/Line
DANO2014
I have a 2002 Allegro Bus with Cat 330 HP!
I am not having any problems "YET" both
engines running great, Cat & Generator ( Deisel)
. How often & where should you check for water?
Is there some kind of bleed-off valve around
Fuel Tank & Or Fuel Filter? Appreciate
any & all information on this!
Thanks,
DANO2014
Allegro Bus 2002
Retired: Cameron Iron Wks
U.S. Army Veteran
Louisiana Masons
6 REPLIES 6
DANO2014
Thanks to RV Net Forum and its members
for replying to my question. There is so much
Knowledge within this Organization to help
others that are less knowledgable and are
willing to take and most times follow the
replies and/or directives given by others!
Again thanks for the help which is always
Appreciated by me!
DANO2014
Allegro Bus 2002
U.S. Army Veteran
Louisiana Masons
Passin_Thru
Every day you run it is the proper answer and first stop after you buy fuel. Simple rules in trucking work for RVS.
Teacher_s_Pet
Any questions call Tiffin Factory Service @ 256-356-0261 Ask for service department, have your chassis # and Tiffin serial # handy (they want the Tiffin #, but can't help having both available). Both should be on your registration (at least ours is, since licensed in South Dakota) or on a label behind the driver's seat. The tech support will call you back, as going on hold can be quite a while, usually get a call back in less than an hour. The tech support has always been great when I've dealt with them. I believe the hours are 8-3 Central Time, most calls after 2:45 have usually came back the next morning. Our water separator is located inside rear hatch doors in front of the radiator, 2006 Phaeton 350 Cat Freightliner Chassis.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
Ernest
Thanks,
You should have a fuel water separator on the chassis frame rail. It's clear with a tap on the bottom for draining the water off. You should have two filters up on the engine for fuel filtration. The ones on the engine should have been done every time you got an oil change, I do the fuel water separator every 15k miles.
Ernest & Joanne
2000 Tradewinds 300 CAT
2014 Jeep Cherokee Limited
Travelingonthetradewinds.blogspot.com 2014 Alaska Blog
Travelingonthetradewinds1.blogspot.com 2017 South West Blog
wolfe10
Yes, check on your primary fuel filter.
To find out what fuel filters you have and where they are located, contact your chassis manufacturer.
And, if a clear bowl on the filter, you can visually check for water or debris-- no need to drain.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
romore
Is there a tap on the underside of the filter housing?
