โOct-02-2016 12:09 PM
โOct-13-2016 06:44 PM
Ductape wrote:
Make sure the weep holes in your windows are open, if your window design uses them.
โOct-04-2016 10:26 AM
โOct-04-2016 08:22 AM
โOct-03-2016 09:45 PM
doxiemom11 wrote:
Water heater left of our bedroom slide - not in the slide. Water ran along outside wall past toilet area and then was wicked up by the carpet alongside the bed. It only leaked when the hot water was turned on. Took some time before it accumulated enough water for it to reach the carpeted area for us to notice. We then found the drip, drip, drip. Check even if it's not in the slide. Water goes in strange places.
โOct-03-2016 07:01 PM
โOct-03-2016 01:37 PM
โOct-03-2016 01:10 PM
โOct-03-2016 07:47 AM
โOct-02-2016 05:10 PM
Tyler0215 wrote:
If you have had a leak for some time the insulation in the walls will hold a lot of water and will still be seeping into the carpet. You have to find the source of the leak first and then dry out the inside.
Check the roof and the slideout seals.
โOct-02-2016 04:55 PM
โOct-02-2016 01:06 PM
MountainAir05 wrote:
any water line, ice maker, hot water tank. Water moves to the low spot. You you have a sink in the slide. Check the drain line also if you have one in slide.
We have a kitchen slide so water and drain. Both have leaked.
โOct-02-2016 12:30 PM
