Water pouring out from under the coach
fenwickfam
Hello! I'm hoping somebody out there can help us! :)We
Yesterday, we noticed a spot under the motorhome where waster was just gushing out. It is fresh water, on the drivers side and looks to be right under where our kitchen sink is. There is no water leaking anywhere IN the coach, just this gusher outside when the water pump is on. :h
We are not hooked up to any water source... we were using water from the tank. It was fine all day and the day before when we were in it and using it. Nothing changed that we are aware of. We had about a 3 hour road trip, but didn't hit any debris in the road of any sort.
This is a new to us motorhome, so is there a valve somewhere that we should be checking that isn't obvious?
Any help would sure be appreciated!!
The coach is a 2005 Winnebago Adventurer 38J
Thank you so much!
The Fenwick Family
4 Children, 5 Grandchildren
Our 3 Bears (Captain Little Bear, Lady Little Bear and Yogi Bear) and 2 very spoiled kitties
10 REPLIES 10
the_vfox
fenwickfam wrote:
Found it!!! 😄
We took the panel off for the water heater and sure enough, a hose had come off! One good thing about a workhorse chassis, they are high enough to crawl under easily!
Thank you all for your help 🙂
You are so appreciated!!
Glad you found it. If you have not thought about it, you should check and tighten all your hose connections. As a safety feature until you do, i would suggest your water pump stay off when you are not in the coach. Also, while you are away, turn the city water off when you are connected to it. After you have checked all your hose connections, you will have more confidence in your system.
Fox and Angel, fuzz ball cat and crazy Yorkie :S
Don't call me on the weekend, Im out camping.:C
2001 Itasca Horizon DP 36LD 330 Cat and all the bells and whistles
Go Blue, US Air Force(retired)25 years 🙂
enblethen
Thanks for the update!
Easy fix!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
DrewE
Where is your water heater? It may be in that general vicinity.
Basically what Vulcan suggested is about all you can do—hunt down where the water is coming from, either by looking from the outside or digging around the inside. The plumbing is usually somewhat accessible from cabinets etc.; you may have to remove drawers or unscrew certain access panels inside to see things.
Does the pump run continuously when it's on but not taps are open? It should shut off once the system is pressurized, and not run until you draw water from somewhere. Anything else indicates a leak. (Sometimes the pumps do leak a bit at the check valve built into the pump, in which case it may run for a second or so every half hour without water leaking anywhere externally. If that is the case, it's nothing to really worry about too much.)
rgatijnet1
If you would have just topped off your fresh water tank there is an overflow hose on some coaches that will continue to siphon water out of the tank.
fenwickfam
Found it!!! 😄
The Fenwick Family
enblethen
Low point drain plug missing or valve open?
Bud
USAF Retired
Pace Arrow
Triker33
Yep!!! Ya are just gonna have to crawl under there and have someone turn the pump ON to see where it is coming from.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
fenwickfam
The compartment where the water pump is located is dry and the location where the water fill valves, outside shower, etc. are located is dry, too. I can't find any leaks anywhere in any of the basement locations or in the coach itself, just under in that one spot.... if that helps or makes any difference.
The Fenwick Family
1492
Moderator
Moderator
Moved from Forum Technical Support
Vulcan_Rider
IF nobody with a similar model gives you any good clues...........you are just about gonna have to crawl under there and have someone turn the pump ON to see where it is coming from.
Before you do that, however, check the hoses and valves in the compartment where the pump IS. Sometimes the water will finally leak out of the floor several feet away from where the leak actually is.
