What Alison tranny do I have??
gsf35099
Can anyone tell me the best and easiest way to determine what Alison tranny I have?
Freightliner XC chassis with 300 Cummins, 5 speed Alison tranny ( D, N, R, & up/dn arrows) on control panel. 2005. Manual does tell which of the 2000, 2100, or 2500 I have. Any idea where the serial number is? Alison website would then give me details.
Thanks.
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
7 REPLIES 7
Electrix
With the push-button shifter you have a 3000 series. It is a full fly by wire system.
2000 series have a T bar type shifter with a mechanical pull cable down to a lever on the lower left side of the transmission.
ID plate is on the right side of the transmission.
Coyote74
There should be a plate on the trans, side, front right or left. About 2x3" with info
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
Blaster_Man
When you find the serial number, call Allison.
2014 American Eagle
bamaboy473
Try looking inside the bedroom closet for the several build sheets; especially the one with the large FREIGHTLINER logo on it. It tells which tranny is in the drivetrain.
2007 Mandolay Valencia 36A
Freightliner, Cummins ISB, Allison 2500
BobandShaz
http://freightlinerchassis.com/RV-Chassis/rv-chassis-article/menu-id-150.html
This may help.
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
gsf35099
Thanks, that helps some. Now to find the serial number.
sch911
A brochure for that model says it's a Allison MH-2000 - 5 Speed.
The brochure is here.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
