Sep-21-2018 07:40 AM
Sep-22-2018 11:06 AM
Bruce Brown wrote:Definately a leak problem after the roof blows off or peels back, I agree 🙂 🙂Mile High wrote:
It's not a leak issue, but I'll argue with Bruce on that until I pass this planet 🙂 It actually can't leak through there if the weep holes below are clear. The seal is a mechanical adhesion issue that keeps the roof flap sealed to the awning rail. If it is allowed to come loose, the wind can get under it and it will peel your roof back.
I you can push back on the fiberglass and it separates away from the awning rail, the sealant has failed and needs to be replaced. The sealant adhears the the fiberglass flap to the awning rail as shown in the diagram. There is no sealant behind that flap.
Our friends was a 2000 Adventurer. Didn't you say Winnie had changed the design a few years back to the current way? I honestly don't remember, but it seems I read that somewhere? Then again I'm old, so the memory isn't what it once was! :B
And on a side note, if the roof peels back I'm pretty sure it would create a leakage issue. :B :B
Sep-21-2018 08:20 PM
luberhill wrote:Bruce Brown wrote:
There are different grades of Eternabond. I'm not sure what that stuff was in the video but it didn't look like any Eternabond I've ever used. I used Eternabond on my TT and it worked great. A TT will have a lot more movement than a motorhome.
But hey, it's your deal, do what you want to do.
What kind of roof is on your pusher
Sep-21-2018 07:48 PM
Sep-21-2018 07:43 PM
Sep-21-2018 07:42 PM
Sep-21-2018 07:17 PM
Sep-21-2018 06:57 PM
John Wayne wrote:
Do like Bruce Brown said use Eternabond tape on the side roof seal and the cap to roof seal and you won't have to worry about it for year to come.
Sep-21-2018 03:22 PM
Sep-21-2018 03:14 PM
Sep-21-2018 03:07 PM
Bruce Brown wrote:
Depending on what color you're dealing with, if it didn't look silly you could Etrnabond it and be done with it. That's what we ended up doing on our friends Winne when nothing else would hold. Etrnabond ended the leaking once and for all.
Sep-21-2018 02:59 PM
10forty2 wrote:
Dicor makes both the self-leveling for flat surfaces and a non-self-leveling for corners and vertical surfaces. It's good stuff. I'd recommend having one of each on hand....but yes, it does have a shelf life and it will go bad if you don't use it for a long time.
Sep-21-2018 02:00 PM
Sep-21-2018 12:55 PM
Sep-21-2018 11:58 AM
