Where does the little red wire go
Tom_Barb
I have a Banks OttoMind engine calibration Module. There is a 4 wire cable that runs from the module to the instrument panel. the 4 wires are Black, (common ground) Green (gauge) and White (gauge) and then there is a red wire, that has a small blade connector. The red wire is disconnected and there is no obvious place for it.
This system worked until about 4 months ago.
Yes I know it is an old system, but it worked?
We installed a new back up camera, and this wire must have been disconnected behind the instrument panel some how.
I checked for + power, not powered
10 REPLIES 10
Tom_Barb
It's over, we must upgrade.
Any opinions ?
on boost gauges? EGT gauges?
https://www.agdieselsolutions.com/product/12100/
enblethen
I am surprised that Banks doesn't have obsolete manuals on website.
Good luck!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom_Barb
enblethen wrote:
I went through Banks site and didn't find your model number. You could try calling Eric Davis over at Eric's RV in Sequim. He did a lot of work with Gale Banks.
that engine calibration module , is way of date.
banks is sending a owners manual for it.
But looks like I'm in for a updated module but not for banks.
enblethen
Bud
USAF Retired
Pace Arrow
Tom_Barb
enblethen wrote:
Go to Banks website with your exact product part number for the instructions if you don't have them.
What is your Banks part number?
62663
enblethen
Bud
USAF Retired
Pace Arrow
Tom_Barb
enblethen wrote:
Not sure if this is your exact product. Page 16 says power.
Manual
This is not a "Stinger pack' and this system is on a cummins 8.3 ISC
Thanks for helping.
enblethen
Manual
Bud
USAF Retired
Pace Arrow
rgatijnet1
As mentioned red is usually for power. Perhaps it is used to power the back lighting at night.
Bruce_Brown
Moderator
Moderator
Red is normally power. I would suspect it goes to a keyed hot in your fuse panel.
I could be wrong, but I'd also guess a call to Banks would also answer your question.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
