Wierd bathroom water problem
dshinnick
Hey all-
It's a 2015 Itasca Sunstar, aka Winnebago Vista.
The flow of COLD water to our bathroom, the water closet, has gone down to almost nothing, perhaps 1/4 of its normal flow. Here are the facts:
- The slow flow appears at the toilet and in the sink, both in the same "closet".
- The HOT water in the sink, right next to the toilet, appears normal.
- The shower, directly opposite on the other side of the coach, seems normal, both hot and cold.
- The kitchen sink seems normal, hot and cold.
- Water pressure from the park is normal.
- Turning on the pump had no effect; cold water in toilet room still slow.
- This just started this morning. Outside temps are in the high 50's.
So it would seem that the cold water line, common to the toilet and toilet-room-sink has become clogged or restricted somehow? Not sure what else could account for this.
I may have to call a pro on this unless someone here has an idea. Any thoughts?
Thanks in advance-
Dave
18 REPLIES 18
ksg5000
Have you double checked the cold water drain valves leading to the bathroom?
Kevin
way2roll
Navigator
Navigator
Water sources at CG's are notorious for having a lot of sediment in them as often they are wells. The screens at faucets get pretty clogged up as do the screens on the water pumps. Try cleaning those out.
Jeff - 2023 FR Sunseeker 2400B MBS
rgatijnet1
I found a lot of debris in my water lines on the RV. Just disconnect one end of the cold water line and let it pump in to a container until the flow picks up. You also need to clean the filter screens at the end of each faucet on a regular basis to remove the debris particles.
Rick_Jay
Just a wild guess, but is it possible one of the winterizing valves or water heater bypass valve(s) got moved?
I believe Winnebago has all the plumbing diagrams on their website, so I'd recommend you check them out to see exactly what might be causing the issue.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
