Jun-05-2020 06:38 AM
Jun-05-2020 04:02 PM
Jun-05-2020 03:15 PM
Jun-05-2020 09:44 AM
Jun-05-2020 08:06 AM
TC&Z wrote:
We have the classic Winegard crank up wing TV antenna (12 yr old) on our MH roof. A branch caught the cable loop as it enters the antenna head and broke it, so I need to replace it. I have pulled the rubber boot off where the coax enters the rotating base and found a blob of potting goop to keep water out. Is there a coax connector under this goop so I can replace the exterior coax? Any one know? If so I will dig it out, unscrew the connector and replace the entire exterior cable. I hope it is not just a cable pass thru to the interior. If so, then I have to crimp on new connector and splice it.
I also want to replace the coax rubber boots. Are these available somewhere?
Anyone's experience with this would be appreciated.
Thank you
Jun-05-2020 07:03 AM
