winnebago and flush mounted lights
Hank85713
Question. We have a 21012 Winnebago Aspect and one of the lights has burned out over the dinette. I know they twist the lens off but I have one that I cannot get to move. Has anyone else had this issue and what did you use.
These are the ceiling flush mounted flat lens light take a H5 Bulb I think it is. I took the one off I had a bulb go bad in before and it has small dimples to hold it in once turned but for whatever reason I cannot get a grip on the current one.
Thanks Hank
3 REPLIES 3
Dakzuki
I got rid of all those halogen bulbs and converted to LED. Same color, same brightness, no heat, and no more burning out bulbs.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
avan
As said, a slight pull down and a bit of a twist.
www.putt10.net
Duck
In my rv you can pull it down a little and get a better grip on the lens. You can take it all the way but be careful because the light is held in place by strong springs . Acts like a mouse trap.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
