Winnebago Vista 26HE sway bar links
getgoin
Hello all.....
I got my hellwig products adjustable links put on.....after much thought and exam....I had moved to the inner hole (CHF) with stock links.....too tight, IMO. So I get the hellwigs and measure to between the holes, add a bit for ride quality. I set links to 12 3/4" C 2 C figure this will be softer than stock link in lower hole yet tighter than stock??? The angle looks good.
Edit....dimension between sway bar holes taken with stock links in inner hole
Any and all info of the experienced welcome.
I suppose retired, on 4/1, machinist 40 years, may be thinking too much?
Sumo's come Monday
0 REPLIES 0
