Winter Storage Questions
Big_Blue
Great first season in our 2008 Winnebago Destination/DP. Alas, winter will be coming to soon here to Maine. Due to other obligations, its time to put the toys of summer away now.
Winterizing the fifth wheel was easy. Drain the lines, put the pink in the lines, drive to winter storage location, remove battery and return in the spring.
Class As are a wee bit more complex. The research that I have done is primarily focused on draining the lines and putting the pink in the lines. I get that.
(I have located indoor winter storage for a reasonable rate. This opens the driveway up for safe snowblowing, et al.)
What about the diesel fuel in the tank? Leave alone or add the winter additive? Fill the tank or ????
The batteries are another concern. All the research says to charge them up monthly. Which assumes that there will be unfettered access. Unfortunately, that will not be the case. The batteries will be fully charged when the rig is put into storage.
What I'm thinking is to disconnect the house batteries from the coach. Setting the battery Aux Batt Switch to off. And return in the spring with a battery charger and good book to read while getting the charge back up to operational.
For those of you who do long term storage over the winter. What have you done? What have you learned? What are the dos and don'ts?
Tnx in Advance.
Bob & Patty Smith
both USAF Retired
16 REPLIES 16
bshpilot
drain the hot water heater too.
Im no reference for cold temp storage but we also have enclosed storage but this might give you some ideas....last year i didn't even blow out my water lines (or run any antifreeze thru them).
I have 50A electric service in our bay (but rarely use more than a 15a service/outlet).
i use some hi/lo recording Thermometer that recorded the low temp (inside & outside) the coach (it rarely gets down to freezing here in texas)....but if it gets close to freezing i turn on some oil filled radiant heaters.
my storage bay is close to home so when it gets cold i stop by the coach to monitor the recorded temps and turn the heaters on (low)
Don R.
'04 42' Haulmark Motor Coach - 450hp/1650tq / 12 spd SmartShift
'12 Jeep Wrangler Sport (manual trans)
'17 Platinum F350 (6.7L, SRW, CC, Long bed, 4x4)
jplante4
I learned one thing last year. The coffee maker has a water reservoir that cracks open if you leave it in the bus all winter. Figured it out on the morning of the first trip in the spring. This year the coffee maker comes into the S&B.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
