wiring distribution chart for travel-lite class b 210
timplace
I cannot locate the circuit breakers for the 120v system in my RV. The manual I have says "it is usually in the coach". Not very helpful. Any clues welcome!
4 REPLIES 4
Gene_in_NE
timplace - What you should have found is behind a swing down door on the converter. Mine is located in the same cabinet as the sink. Looks a little like this -
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
timplace
Found it hidden in what I thought was the water heater panel.
Arizona_Kid
As far as I know Travel-Lite only makes TC, and TT.
Did you mean Trail-Lite 210? If so you should ask Admin to move this to the Class C forum. Several owners over there.
Trail-Lite is what many call a B+, but that is just a term for a small Class C, with no overhead bunk.
1492
Moderator
Moderator
Moved from Forum Technical Support
