Aug-26-2013 02:40 PM
Sep-14-2013 08:38 PM
Foggy wrote:
Is removal really necessary? I think just using up the Sunday paper for masking would be easier.
Sep-14-2013 04:48 PM
Sep-02-2013 08:24 AM
wr1032 wrote:
Had the same problem on a 2003 Jayco, went back to dealer, they did not see a problem. Only time MH sets out is on trips. Will try painting. Dealer has been good to me on other issues, Will not push the mirror issue.
Bill
Sep-01-2013 01:21 PM
Aug-31-2013 05:25 PM
Aug-31-2013 05:10 PM
TJDave wrote:Thanks!! I will put that on my "to do" list. Happy travels.Kit Carson wrote:
OOOOPS, I did not do that right. Was it hard to remove the mirror head from the arm?
Not in the least. One allen head set screw unloosened, and the whole thing pops right out.
In fact, if you look closely at the "before" pic I posted, you can see the only tool I used hanging off the mirror.
Aug-31-2013 12:21 PM
TJDave wrote:cal47 wrote:
Easier fix isto contact Velvac,they replaced my mirrors at no cost. They had a problem with their paints for quite awhile. Give them a call,you might get a new set.
Really? Mine is an 06 Model. I wonder if they would warranty them as old as they are.
Guess I better call them. Thanx for the info!
Aug-31-2013 07:22 AM
Aug-27-2013 08:47 PM
Aug-27-2013 05:12 PM
Aug-27-2013 05:11 PM
TJDave wrote:
It has probably already been covered here, but I thought I'd share my results. My 06 Ford Four Winds class C mirrors have been progressively getting worse due to sun and weather exposure.
An easy fix if it bugs you like it did me. Krylon Fusion plastic paint, some painter's tape, and a fine grit sanding sponge.
I am happy now. Was it hard to get the mirror head off the arm?
Aug-27-2013 09:59 AM
Aug-27-2013 07:50 AM
Aug-27-2013 07:40 AM
