โSep-12-2017 11:39 AM
โOct-06-2017 09:56 PM
Rbur wrote:
Blackstone 17 regulator has a straight fitting smaller than 1/8โ . They shouldโve made it a standard size. IMO
โOct-05-2017 08:38 AM
โSep-13-2017 01:37 PM
wowens79 wrote:fpoole wrote:
Low Pressure hose...
I've be wrestling with the hook up to the Camper's LP hose, quick connect, figure the same, a direct line to the BBQ (in this case) but how are you going to regulate the flow from Low to Hot...
It just dawned on me to use the flow valve on the Low Pressure Camper connection, but are you using something else??
Thanks..
On the Weber Q the gas still goes through the control valve on the grill, and would do the same on the Blackstone. The Q is a very simple connection. The way the Blackstone is made, I can't see the insides to see how I would have to connect.
โSep-12-2017 08:42 PM
neschultz wrote:
Here's what I did to convert it:
Remove the black tube that has the weird connector on it from under the Blackstone. Put it in a vise and remove the factory connector that screwed to the regulator. Replace it with a male 3/8" compression to 1/4" NPT male adapter (Lowes sku 645791).Then add a double female 1/4" NPT connecter (Lowes # 645697)...you could also use a right angle here if you'd rather (I wanted to keep it straight to still use the regulator). Then a 1/4" NPT male to quick connect male. Don't forget to use propane tape or sealant and check for leaks.
The flow is still adjusted with the factory flow valve.
Let me know if you find a better way!
I also added adapters to the regulator so it connects to the quick connect now on the grill - so we are still able to use the regulator with cans in the backyard at home.
โSep-12-2017 03:01 PM
โSep-12-2017 12:10 PM
Thanks..
โSep-12-2017 11:43 AM
