โAug-05-2019 04:40 PM
โAug-06-2019 04:22 PM
opnspaces wrote:
Interesting solve, glad you found something. I'm assuming you want to keep Connectivity installed on the PC which is why you aren't deleting it.
Funny (morbidly) thought on your system in the event of an untimely demise. I've had the same thoughts about me and my system and even went so far as to draft RTF documents (in case word isn't available but want pictures) in appropriately named folders. But truth be told, if something happens to me, my brother who was a network engineer for years would probably just rip it all out and re-flash one router to serve wifi and connect to the cable modem. The rest of the stuff would go right in the trash. It's like nobody appreciates the care and coolness that we build at home.
โAug-06-2019 03:41 PM
โAug-06-2019 03:11 PM
โAug-06-2019 01:55 PM
opnspaces wrote:
This is foreign to me as I live where a long driveway is maybe 50'
โAug-06-2019 01:36 PM
RLS7201 wrote:
I would suggest router 3 have a static IP address of 192.168.3.1. Router 2 could issue a IP of 192.168.2.1. See the conflict?
Richard
โAug-06-2019 01:30 PM
โAug-06-2019 10:36 AM
opnspaces wrote:
You might have better luck , but I have tried running my firewall and cable modem of a standard grade UPS (APC) but it doesn't work so well.
Consumer grade UPS's are not continuous battery backup but just route the utility power straight through to the devices and also keep the battery charged up. If there is a power interruption the UPS quickly switches to the battery and relies on the capacitors of the PC's power supply to keep the PC alive long enough for the switchover to occur. I think the capacitors in the small devices like a router are just not sufficient to keep the router alive while the UPS switches over.
โAug-06-2019 10:25 AM
TNGW1500SE wrote:
PS: Adding a 4th soon so I have WiFi down at my gate for a wireless IP camera. It will hook to the Garage access point router and be a wired connection 100 feet away from the garage. Then it can WiFi the rest of the way to the gate. I hope! It's a long way. To far for a Ethernet cable.
โAug-06-2019 10:11 AM
โAug-06-2019 09:59 AM
โAug-06-2019 08:57 AM
โAug-06-2019 05:40 AM
opnspaces wrote:
.......If rebooting the affected devices restores them to the 2.1 subnet, then yeah your only answer is in going through the logs of the various routers and see who assigned the IP.
โAug-05-2019 05:01 PM
